SC430 Owners Wheel Size/Offset Roll Call
Old Oct 27, 2018 | 09:00 AM
  #31
texsexlex's Avatar
texsexlex
Originally Posted by Prasha
I have 245/35/20 in the front, 265 in rear
.....245's will work, in most cases, but do you have 10in wide rims on the front ???
Old Oct 27, 2018 | 09:10 AM
  #32
texsexlex's Avatar
texsexlex
Originally Posted by BGinLA
D2s are “still” ? Or firm . Got it! Even at the softest setting they are firm? Why’d you go with the D2 by the way?
...my car is lowered, but on springs. I personally wouldn't know the difference in the ride between the coilovers. One thing to keep in mind, when lowering a vehicle, it's going to ride a little firmer/rougher. If you lower it an inch or two, you are taking away travel in the suspension, so the new setup has to keep the car from bottoming out & this is where the firmness comes into play. My car is dropped 2 inches & really doesn't ride that bad, but some bumps or rough roads will remind me that I'm literally on the ground...lol......good luck with your decision !!!
Old Oct 27, 2018 | 09:33 AM
  #33
Prasha's Avatar
Prasha
all 4 rims are 8" front tires are 245s and rear tires are 265 on factory suspension
Old Oct 27, 2018 | 09:40 AM
  #34
texsexlex's Avatar
texsexlex
.....thats why you are able to run the 245 on the front,because of the 8in wide rim.The OP is using a 10in wide rim & thats why I told him it may rub
Old Oct 31, 2018 | 09:57 AM
  #35
bgeeez's Avatar
bgeeez
Considering a wheel set like this
19x10 on all 4 sides
offset +42
tires: 265/35/19 front and rear , no stagger.
Have not seen anyone in the posts with this setup. Anyone comment!? Yes, I will likely run D2 coilovers. Curious about Fitment . Looking for a clean stance, not overly aggressive.
i have 19x10 et 38 all around. 255/35/19 in front it would hit the control arm turning so i added a 3mm spacer. 285/35/19 in the rear rubs occasionally on big dips
Old Oct 31, 2018 | 01:03 PM
  #36
Bgw70's Avatar
Bgw70
Veteran: Air Force
you are correct, they are firm at the minimum setting. I thought they would be softer. I chose the D2s because of price and what I was told on the forum. A CL sponsor sold me the coilovers. I thought they seemed okay to give them a try. Plus there are virtually no options in the normal dampners for our cars.
have you used coilovers on previous cars and are there softer riding versions?
Old Oct 31, 2018 | 02:49 PM
  #37
BGinLA's Avatar
BGinLA
Default Yes I’ve never used coilovers so
so this will be my first time. Anyone else use D2 or BC or Meister R??
Old Feb 17, 2019 | 07:19 AM
  #38
twocell's Avatar
twocell
245/40/17 front w/.75" spacers ... 275/40/17 rear w/1.5" spacers
Old Apr 23, 2019 | 05:41 PM
  #39
CLee55's Avatar
CLee55
Default Offset Question
Just wondering with the +25mm offset, would you wheel still fit under the fender, or is it flush, or is it sticking out past the fender? Thanks in advance.
Old Apr 25, 2019 | 12:47 AM
  #40
ivanj's Avatar
ivanj
Default Handsome ride!
Originally Posted by Hermosa
STOCK SETUP
Front Rim Diameter, Width, and Offset: 18x8 +45
Front Tire Dimensions: 245/40R18
Front Wheel Modifications Needed: None
Rear Rim Diameter, Width, and Offset: 18x8 +45
Rear Tire Dimensions: 245/40R18
Rear Wheel Modifications Needed: None
Attachment 440361
Picture courtesy of Talwang
Does anyone know the weight of the stock wheels? I've looked, but have not found....
Old Nov 17, 2025 | 02:08 PM
  #41
suebaileybuddy76's Avatar
suebaileybuddy76
1st Gear
Default Question re wheels
Originally Posted by OBP
TSW Nurburgring
Front Rim Diameter, Width, and Offset: 18x8 +35
Rear Rim Diameter, Width, and Offset: 18x8 +35
I’m confused and hoping you can help. I like your wheels amongst the 50 or so options out there I’ve shopped for my ’07. But the TSW site sez the Nurburbring wheels won’t fit!?! This is especially puzzling as you noted that you didn’t make any modifications. And yes, I’ve the same size tires as you. Any idea what’s going on here? Thanks in advance for your response.
LF
Old Nov 17, 2025 | 06:35 PM
  #42
OBP's Avatar
OBP
Talk about a blast from the past. Did not think my post from 2017 would be seen by anybody ever again. @suebaileybuddy76 , over the years the TSW website has become generally more confusing. I tried replicating a search for the TSW Nurburgring and got nowhere. Possible that they simply do not make the Nurburgring in the correct size/bolt pattern etc etc for the SC anymore. I bought mine probably 10 or more years ago, guess things have moved on in the new TSW rim market ? Just my best guess. Sorry not to have better info for you ....
Old Feb 16, 2026 | 06:12 AM
  #43
2002MikeV's Avatar
2002MikeV
1st Gear
A year late , but I weighed a stock rear wheel with a non-stock tire (Sailun Atrezzo 245/40ZR18) yesterday and it came to 50 lbs 5 oz. Without pie plate and bolts it was almost exactly 50 lbs.
Specs on the tires say somewhere between 24 and 25 lbs new, so the stock wheels are in the ballpark of 26 lbs.
Aweera
Dec 10, 2022 01:50 PM
snook
Jun 22, 2009 08:04 AM
Alexus-Kia
Wheels, Tires & Brakes Forum
Jul 9, 2004 09:29 AM
GS400drive
Dec 8, 2003 08:57 PM
Jasono31
Jun 27, 2001 10:23 AM
