Tps
Old Apr 28, 2007 | 05:29 PM
kevin28269's Avatar
kevin28269
Default Tps
Does any know how to change a Throttle Position Sensor on a 2002 sc430, thanks
Old Apr 30, 2007 | 11:45 PM
menappi's Avatar
menappi
do you have a picture, I don't own a 430 but I could probably tell you how if you had a pic. it's most likely a bolt off/on affair.
Old May 1, 2007 | 12:24 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
You will need an OBDII scanner that will give out the sensor angle. if you have this I will shoot over the instructions on how to proceed.
Old May 1, 2007 | 04:57 PM
kevin28269's Avatar
kevin28269
Default thank
I mean if i pop out the engine cover I will see the sensor right on the throttle, but I need to know the adjust and angle that it need before messing with it.
Old May 1, 2007 | 06:32 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
OK, as long as you have an ODBII scanner or Toyota scanner you can do this. I will get the throttle angle to you later when I have access to it.
dlamb89
Jun 13, 2015 04:22 PM
frankjames
May 12, 2009 06:00 PM
want sc300
Nov 8, 2007 05:04 PM
