Daizen sway making noise
Old Nov 17, 2006 | 12:37 AM
hlee1169's Avatar
hlee1169
Question Daizen sway making noise
Just installed the Daizen sway bars on my 06 SC430. It was making rattling noise under the driver side, so I took it back to the installer and they said it was a loose bolt. After the correction, the noise came back 2 days later, so I have to take it back again. I am wondering if anyone has encountered this kind of problem with the Daizen sway bars?
My impression of the sway: it got rid of the floating sensation and the whole car feels tigher. Body roll is far less than the stock sway. I would recommend it 100% if I could get this noise fixed.
Old Nov 17, 2006 | 01:54 AM
talwang's Avatar
talwang
Did your installer use Loctite?
If not, it is probably where the problem is providing he has greased the bushings and torqued all the bolts properly.
Also, you need to make 100% sure he had rotated both front endlinks 180 degrees before he installed the front sway bars. Otherwise, your front sway bar was not installed correctly at all.
Do a search for Pearlpower's previous threads for more info.
Old Nov 17, 2006 | 09:37 AM
rominl's Avatar
rominl
exclusive matchup
yeah i believe you have to use loctite. and yes you have to flip both front and rear end links i believe, especially if you have stock suspension
Old Nov 18, 2006 | 05:32 PM
hlee1169's Avatar
hlee1169
Thank you for the advice, i will pass it along to the installer on Monday. By the way, if he can't get it right, can you recommend a competent installer in the bay area? I am in San Jose, thanks.
Old Nov 21, 2006 | 12:33 AM
hlee1169's Avatar
hlee1169
An update: the installer did not use loctite, and the bolt at the end link is loose again. Now I will see if loctite solves the problem. Thanks for the help.
Old Nov 27, 2006 | 12:29 AM
G Star's Avatar
G Star
TM Engineering. The sway bars should've been installed there from the start.
Old Nov 29, 2006 | 02:21 AM
rominl's Avatar
rominl
exclusive matchup
go to exact motorsport, most of us go there and never a complain
you can read more in the norcal forum (towards the bottom of the main forum page)
ay3333
Jan 8, 2014 02:01 PM
LexiGS
Suspension
Dec 11, 2011 03:05 PM
Wine Guy
Aug 15, 2009 08:22 PM
Threxx
Suspension and Brakes
12
Nov 12, 2005 08:07 PM
sc400
Jul 1, 2003 06:17 PM
