How to disable tire-pressure monitoring (TPM) system?
Old 06-16-11, 07:51 AM
  #136
mandyfig
mandyfig's Avatar
Lose the TPMS sensors all together.
Old 06-16-11, 11:29 AM
  #137
Tensi
Tensi's Avatar
Advantage of that over disabling?
My question is retaining the sound on extreme deflated situations without having the light.
Old 06-16-11, 12:08 PM
  #138
mandyfig
mandyfig's Avatar
Sorry I think we can not pick and choose on this feature.
Old 06-16-11, 12:25 PM
  #139
Tensi
Tensi's Avatar
Although the sensors have the light on permanently, they seem to still work in warning when completely flat with the audible warning.
Old 06-16-11, 12:26 PM
  #140
Tensi
Tensi's Avatar
You pulled the sensors? and not just the control under the console??
Old 06-16-11, 01:43 PM
  #141
mandyfig
mandyfig's Avatar
Nope. Means just follow the instructions here. Means de-activate the TPMS system.
Old 06-16-11, 07:37 PM
  #142
grabber2
grabber2's Avatar
my TPMS light was "ON" since the day one. It didn't make any noise, but it never went away no matter what I did. I have it now at 32psi each non-run flat. Does it mean my TPMS fail or what??
Old 06-17-11, 07:39 AM
  #143
mandyfig
mandyfig's Avatar
Your TPMS was probably not working. Diasable it then.
Old 06-17-11, 08:46 AM
  #144
grabber2
grabber2's Avatar
Woo!!....took me 3 mins....that was "easy", However, I now hear a minor electric noise :"emm-emm, zim" that last about 1~2 second when I plug the key & turn it to on (before ignition), I re-plugged the TPMS cable and I still hear the noise. I now hear it everytime I turn the key to on
Was it there all time that I just didn't notice??? Any have that noise??
Old 06-17-11, 10:28 AM
  #145
redliner8
redliner8's Avatar
My steering wheel makes that noise when it extends when I put in the key
Old 06-17-11, 11:02 AM
  #146
grabber2
grabber2's Avatar
no it wasn't the steering wheel noise.......I hear it when I turn the key to "on" without it fire it up
Old 06-19-11, 10:36 PM
  #147
texsexlex
texsexlex's Avatar
...do you think it could possibly be the antenna motor ???? I do hear mine when i turn on car,if the radio is already on...just a thought
Old 06-21-11, 07:50 AM
  #148
grabber2
grabber2's Avatar
Nope, it wasn't the antenna, anyway it doesn't bother me, dodn't see anything wrong with the car. might just be the TPMS looking for the plug.....lol
Old 06-26-11, 04:40 PM
  #149
maxr
maxr's Avatar
Smile Thanks for sharing, and the opportunity something new.
T
Originally Posted by Hans ****
I'd like to share my frastrating TPM experience with you and want to find a simple way to have TPM disabled.
when I had my OEM rims replaced by aftermarket ones, a damaged TPM sensor was found and I have to replace it. When a sensor was missing, the car beeps 5 times for every 2 and a half minutes and tire pressure warnning light keeps flashing.
I called up a lexus dealer to check on the price. It costs about $200 before tax for one sensor. I did not like dealer's price and luckly enought I found the parts from Internet and it costs about $100. After sensor was installed back to my car, the beeping and flashing wont go away. I went back to dealer and thought that must be a simple setup thing, but it turned out that they have to unmount all four tires in order to have the code for each sensor so that they could reprogram the controller. They need 4 hour to do that. The labor cost is $85-$150 per hour so it's running at $340-$600 to get controller reprogrammed. I still could not understand why they need to reprogram 4 instead of 1 since I only have one new sensor.
I did ask them few more questions reagrding to the sensor itself and here are what I learned
The sensor is not a passive part, it have a battery built-in. The battery can only last 4 years! Flat battery can not be changed since it's built-in, meaning that when battery is run out, the sensor has to be replaced! I could not believe lexus would use such a fatal product on SC430.
I wanted to have TPM system disabled but they told me there could be a way to do it but they wont do it for me because by "law" I have to have it. I don't care about the "law" and once I know how to disable it I'll go for it.
BTW, there are four different color coded sensors. when order sensor from Internet thay need to know the color.
Thanks for sharing, and the opportunity for me to learn something new about my 2003 SC 430 with 108k miles.
Old 07-02-11, 12:56 PM
  #150
A1Lexis
A1Lexis's Avatar
Took me 2 minutes to disable and reassemble everything. Thanks for the pics and DIY mandyfig!
Quick Reply: How to disable tire-pressure monitoring (TPM) system?
