Very annoying (and loud) sound behind center air vents. Anybody else?
Old 11-24-05, 08:12 PM
JCtx
JCtx's Avatar
Default Very annoying (and loud) sound behind center air vents. Anybody else?
It just happened yesterday on the freeway, as I hit a small bump. Need to mention this stretch of freeway has those extremely annoying ridges that make everything rattle inside the car, besides the deafening tire howling. But after they're gone, all used to be well. Yesterday, after said bump, this very loud noise behind the center air vents started all of a sudden. It increased with speed. Sounded like a motor turning. Thought it was the NAV motor (which I never use), but opened it and closed it, and it functioned well. Tried the motor for the stereo cover, and also worked fine. When the motors were operating the sound persisted. The noise disappeared below 50 mph. And not even in broken pavement was present. After speeding above 50 again, now in smooth pavement, it was back. I guess it's there to stay... until 'killed'.
I HATE dealers going on a fishing expedition in my cars, so prefer to know what the heck is causing it, and preferably do it myself (don't trust the only dealer in town). Anybody has had this problem?? I'll try to tackle it myself, but no way I can live with that noise, so a trip to the dealer seems almost certain (aaaargh!), as I don't have a service manual yet to get behind the dash. Hope somebody can help. Wish everybody had a great Thanksgiving.
JC
Old 02-15-07, 08:24 AM
rclab1
rclab1's Avatar
Default I have the same experience.....
I know its not the tire making the howling noises, I have the same experience as mentioned up above on the post.
What was the cure? what did the dealership say it was?
Its very annoying howling noise......
Old 02-15-07, 10:23 AM
hipendicul
hipendicul's Avatar
Hey if the noise your talking about sounds alot like a loose piece of trim.. you know the ones that go away once you put your hand on it... then it might the nav unit.
My car had a very annoying rattle that would only show up every now and then and I tried to quiet it by touching the doors to the radio, trim, etc but nothing helped.. I tore apart my center console and tightened everything up there and thought I got it. But it was the same.. So it had to be something in the nav or the AC controls, both I ripped out thanks to Dan loaning me his manuals.. Well as it turns out my nav unit lost a screw on the side of the unit and after putting in a new screw, my car is very nice.. very nice...
To rip out the Nav unit you will need to pull the left center vent (there are two clips that have to be undone in the vent and then while holding them in, you just pull, use a flashlight and you will see the two holes in the vent) and the wood trim/right center vent, also needs to come out (again two clips in the center vent and hold them in and pull, you may need an extra hand with this). Then pull the AC control (mine was very very tight and I had to pull very very hard.. becareful) and then the nav unit comes out with two 10mm screws at the bottom and two regular screws at the top. Once out if your missing any screws it will be pretty easy to spot.
I went around and checked the rest of the screws and most were kinda loose, so it wouldn't surprise me if you lost one too.. Hope that works, cause my car feels solid again... (oh and if you need screws (very small machine ones is what I needed), your local hobby store has them..)
Old 02-15-07, 11:55 AM
IcEnPinKi
IcEnPinKi's Avatar
I dunno if that will help you but it will sure help me!!! My Navi door is stuck. Now I know how to take it out!! THANKS hipendicul!!
Mdy49 (03-01-21)
Old 02-15-07, 12:00 PM
MBoom
MBoom's Avatar
You mention it's behind the center vents. Is it possible that it's associated with your HVAC system? While that doesn't seem consistent with the speed-dependent noise you describe, I'd try turning off the HVAC, then manually increasing the fan to its maximum speed. I've had annoying . . . and persistent . . . noises that turned out to the the result of something that was ingested into the HVAC system.
Good luck.
Old 02-15-07, 02:35 PM
rclab1
rclab1's Avatar
Default its not a rattling noise .....
thanks for the input...... but it is not a rattling noise, it is howling,
and it is the not tires either, they are brand new!
howling over and over again, it stops, and howls again,
it happens above 40mph.....it stops howling, then howls again.
it is a very persistant sound, meaning, nothing is loose, seems like its triggered by something behind the vents or dash Board.
"howling noise" !!!!!!
am very confused on what it is....
Concerning the HVAC controls, it maybe that something got injested in it, I turned off and on my fan controls and it is still there.....?!?!?!!?
I have no clue what is howling behind my dashboards above 40mph?, and it is not the wind outside either?.....
has this happend to anyone else?
p.s. I'am not tearing apart my dashBoard.....
Old 04-26-09, 07:10 PM
IcEnPinKi
IcEnPinKi's Avatar
try this.
https://www.clublexus.com/forums/sc-...lfunction.html
Old 10-01-15, 03:05 PM
HIDsightz
HIDsightz's Avatar
There is a TSB about howling and wind noise for our cars might want to look into that
Old 10-01-15, 04:27 PM
Bgw70
Bgw70's Avatar
Please post the TSB or at least the number
Old 10-02-15, 04:35 AM
theazz
theazz's Avatar
My similar problem turned out to be dirty servo motors that operate off your hvac.
There are 4 on the sc430.
Old 10-02-15, 07:11 AM
Bgw70
Bgw70's Avatar
You know, I believe that is the problem with my SC. When I turn the key on, I hear noises from the dash and have suspected the HVAC plenum servos.
Did you happen to clean them yourself?
If so, was it difficult?
Old 10-04-15, 02:20 PM
theazz
theazz's Avatar
Yes I cleaned them myself. Takes a little work getting to them but it was worth it.
Old 01-31-20, 07:44 PM
dommo25
dommo25's Avatar
Default Ticking, clicking, whirring, gurgling noises
Have done an advanced search on my specific problem and discovered it seems to straddle various models. It is best described as an intermittent but VERY annoying ticking or "chattering" sound emanating from somewhere behind the dash slightly to the passenger side.
I have taken it to the dealer TWICE now but Chitty Chitty Bang Bang refuses to cooperate. On the way to the dealer ... tick, tick, chatter, whirr, gurgle ... then mechanic gets in and we drive around in total, awkward silence. Then, as soon as he gets out of the car and I'm on my way the noise comes back. TWICE! The second mechanic thought it may be the servo motors that have been mentioned in other posts (e.g. above) but he wasn't sure (because the sound never materialised). Said it was very rare for them to cause problems in the SC430. He quoted me AUD$1K per servo which may or may not fix the problem!!! I am definitely not confident in any investigative diy process that involves using a screwdriver.
Wondering if anyone has been able to permanently fix this issue without pulling the car apart, or if anyone HAS had the servo motors replaced and, if so, whether this was the actual cause (and subsequent fix)?
Cheers.
Old 02-01-20, 02:36 AM
Bgw70
Bgw70's Avatar
Cheers.
see post #3 & #10 for an example of will eventually happen to the intermittent noise. Mine started out like yours, then it got worse...
also, post #9 explains the problem and fix.
have an independent mechanic fix your car...it’s not a difficult job but you need some tools. I fixed mine myself and it’s been quiet for over a year.
https://www.clublexus.com/forums/sc4...from-dash.html
Old 02-01-20, 02:44 AM
Bgw70
Bgw70's Avatar
Another good thread on the subject...
https://www.clublexus.com/forums/gs-...ete-guide.html
Quick Reply: Very annoying (and loud) sound behind center air vents. Anybody else?
