Passenger headlight problem
Hello members,
I own a 2003 sc430 and my low beam and side marker ( passenger side) lights are not coming on . When I turn the automatic light switch to off my daytime running lights come but when I turn it back to auto no lights come on in the headlights or side marker lights . Could it be a fuse or a relay?
Thanks in advance
Thanks in advance
Do your "High Beams" work?
Take a look at this Fuse Chart, hopefully something will pop up
https://fusecheck.com/lexus/lexus-sc...0-fuse-diagram
Today I inspected my car again and found that the driver’s side headlight worked fine all bulbs inside lit up including the bumpers side marker lights.
But the headlight on the passenger side does not come on at all not even the side marker light on the front bumper . I checked the fuses and all fuse seem fine. Where do I go from here? It seems the passenger side has lost power except for the drl and the passenger side fog lamp.
Thanks in advance for all advice given
Today I had the car scanned to see if I had any codes and non showed up.
does one headlight relay control both headlights?
the side marker light inside the headlight is dead also the only light working is the drl
any help would be greatly appreciated thanks
Andrew300
Sep 26, 2020 02:10 PM
