Thanks guys, I can give a discount for locals and it is OBO so Pm me if you want to make an offer.
Someone needs an aem... please don't make me buy a sc400 to install it on =)
That is a good question, not sure how many go standalone with the stock twins... you may have to go TTC but then you can crank up the boost and even go e85.
Or buy a BW S362 and a quick spool valve like I am planning to do =)
I do like how you don't need a boost cut controller or speed cut controller etc.. and all the failsafes, but you will need a tune for sure.
seems like a good idea, I'm trying to blow the twins before I go single, hate to throw them away. I might be interested if there is a way to run it with a tune, that is if no one buy it.
you can use these ecu's on na-t or even a gte swap, you just need to get the map sensor, intake temp sensor, and get it tuned by a tuner. normal standalone stuff.
I am going to hold off on selling this until I can confirm it is working as intended again I don't want anyone to go through this cycle again.
mods you can close it.
