NY FS: Siemens 850cc Injectors - Aeromotive FPR StandAlone ECU+ Part Out
850cc Siemens Low Impedence Top feed injectors 14mm (6 in total) - $325 shipped.
Aeromotive Fuel Pressure Regulator 13-101 -10AN ports. Will include -10AN plug and -10 to -6AN male fitting. $125 shipped
IS300 coilpacks, IS300 igniter All plugs and pigtail harnesses, Upgrade your ignition on the 2JZGE - $450
Stinger EMS 4424 Standalone.... comes with relays, harness and plugs for a 2JZGE. Will work with the above IS300 ignition and already has a 850cc dynotuned fuel map. $750
Floor Jack (new in box) $25 picked up only.
2JZGE W58 Fidanza Lightweight Flywheel and Exedy Stage 2 clutch kit ... $400
W58 MK3 tranny - comes with 2JZ bellhousing, fork, bearing, slave cyl. - $250
jdmmk3
12-21-13 08:36 PM
