DIY:Painting your chrome window trim
Old Nov 20, 2010 | 05:57 PM
Sc4Jr24's Avatar
Sc4Jr24
Default DIY:Painting your chrome window trim
The other day I decided to paint my chrome window trim and was really pleased of the outcome. And some of you guys had some questions. So here is what i did. I not a pro at painting so please dont bash me to hard.
Please be careful when removing panel because the plastic can be brittle. Stick your pry tool as close as possible to the panel clip when pry. Take your time. I might have missed some screws so look around before pulling panel. I had some missing. Took about 10min to get the chrome trim off.
BE CAREFUL YOU CAN BREAK PIECES.
Roll the window all the way down.
First you have to remove the door panel.
-two screw under the arm rest
-four screw at the bottom of door panel
-two screw at the front of the door panel
-one screw in the door handle behind plastic cover
-pop window switches and disconnect plugs
-there are two small screws on the right side of the door behind to small plastic cover( these help hold the chrome trim)
-disconnect door handle
-double check for anything plugs or screws still holding
Then remove the inner window trim and outer trim and mirror
-four screws at the bottom of inner trim(green)
and the panel should pop of with a little pressure
-three screws that hold mirror and unplug(yellow)
-six nuts up top that hold chrome trim(red) dont forget the two small screws on the edge of the door covered by two small rub pieces.
- the panel should pop right out.
Disassemble trim by removing six screws holding bottom weather stripping be careful the anchor nut rivets can break off because they will be rusted like mine and just pull off the rest of the weather stripping try not to stretch it to much. When reassembling upper weather strip take your time when pressing it back in to get that perfect seal.
You should be left with the black and chrome metal trim with just a little rubber around the edges. I didn't pull that off because I did have any adhesive to glue it back.
Now prep for painting:
-lightly sand just to rough the surface
-wash and let dry
-and apply paint in coats 30mins apart. Take your time.
-for paint I used Rust-oleum universal all surface.
-allow a 24hrs to fully dry.
I haven't did the back window yet because I ran out of paint, but im just gonna tape it off and paint it. I started to remove the inside panel and found that its a pain to remove the inside panels and that the window was only bolted in by four nuts, but the window sealant was holding it pretty good and didn't want to break that.
Old Nov 20, 2010 | 06:21 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
WTF?????
Then what?
Old Nov 20, 2010 | 06:28 PM
VinnyMac's Avatar
VinnyMac
...what a cliffhanger...
Old Nov 20, 2010 | 06:31 PM
Emilio253's Avatar
Emilio253
Lmao, I was really interested too.
Old Nov 20, 2010 | 06:34 PM
nfordhk's Avatar
nfordhk
I think that's as far as he got hahah
Old Nov 20, 2010 | 06:46 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
So that's how it's done?
That's a lot easier than I thought.
Old Nov 20, 2010 | 06:49 PM
OaklandLex's Avatar
OaklandLex
Why wud u paint that just leave it like it is
Old Nov 20, 2010 | 06:54 PM
Sc4Jr24's Avatar
Sc4Jr24
sorry I accidently hit enter and it posted it. I'm not big on chrome.
2jz-sc's Avatar
2jz-sc
this is the best thread EVER lmfao
Old Nov 20, 2010 | 06:55 PM
abounly's Avatar
abounly
Or you could of use plastic dip so you don't have to remove all that stuff. But it looks good.
Old Nov 20, 2010 | 06:59 PM
2jz-sc's Avatar
2jz-sc
Dam I was to late
Old Nov 20, 2010 | 07:05 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
That's a lot better. I liked the blacked out trim.
Old Nov 20, 2010 | 10:40 PM
pieisgude's Avatar
pieisgude
Thanks for posting it up man, i appreciate it. I'm gonna try to do this soon, and possibly try to firgure out something for the rears...
Old Nov 21, 2010 | 03:05 AM
ashtray's Avatar
ashtray
Your car is an OG true fish bowl. Good work on the DIY write up!
Old Nov 21, 2010 | 08:36 AM
Sc4Jr24's Avatar
Sc4Jr24
Thanks. The rears I'll finish next weekend.
