>>>>>>>NEWBS! Read this thread !!!!!!!!!!!
First, try here for repetitive questions: http://intellexual.net/faq.html
Second, if you still have a question, USE THE SEARCH BUTTON.
- To use search properly, designate the forum you wish to search in HERE. This will reduce unneeded threads popping up in search.
- When you need to search a question with only 3 letters like AEM, you need to use a wildcard like this: AEM*
- Try other terms. The center vent for instance that is in the dash is actually called a "register". Also, use as little of keywords as possible to maximize your search.
Third, I cannot stress this enough...... USE THE PROPER FORUM. Engine and drive train related threads go in the engine forum. Steering, suspension, and brake questions go in the suspension and brakes forum (go figure). We have to move so many threads due to improper posting you are likely going to get a tongue lashing if you repetitively do not put it in the correct forum.
Forth- WHEELS and TIRES (including fit and offset questions) go in the WHEELS FORUM here: https://www.clublexus.com/forums/wheels-tires-and-brakes-forum-76/
- there is also a large wheel thread we have allowed to stay in the SC forum here: https://www.clublexus.com/forums/sho...d.php?t=158592
Fifth- Electronics related questions (key fobs, security, audio) go in the electronics forum here: https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics-12/
Sixth- Lighting related questions go here: https://www.clublexus.com/forums/lighting-128/
The rest you should be able to figure out on your own. Good luck and enjoy your stay!
We have a classified forum here: https://www.clublexus.com/forums/general-classifieds-3/
.....and they have a PM box, however beware that you can be considered for PM spam which will result in removal of your access. So before you pm someone to sell them something, be sure they asked for it.
