Huge Transmission issue
Old Jun 8, 2021 | 02:48 PM
jwsc's Avatar
jwsc
Default Huge Transmission issue
Im 16 and just have bought a 97 sc300 with a bunch of miles and runs great, but I have a big issue. When the engine is “cold” it will not shift out of first gear. It just revs super high and will not shift. But if I let it sit for about 10-15 minutes and then drive it, it seems to shift fine and great but sometimes it will random down shift and stop shifting. Anyone have this problem? I just want to know if I need a whole new trans or need to replace a solenoid. Any info would help thank you.
Old Jun 10, 2021 | 10:42 AM
Crackedsc4's Avatar
Crackedsc4
Smile
sounds like ur shift solenoids are going i just replaced mine in my sc400 not the same but i was able to get it done in an afternoon though i would check the service manual for diagnosis
heres a link to a pdf so you dont have to go searching or buy one-https://cardiagn.com/automatic-transmission-91-00-sc300-sc400/
Old Jun 10, 2021 | 04:22 PM
1997Soarer's Avatar
1997Soarer
Do you know the last time it had a trans fluid change?
Old Jun 13, 2021 | 08:14 PM
Stilloem's Avatar
Stilloem
First thing first check DTC code. Then check transmission fluid and smell transmission fluid for burned smell.
Old Jun 14, 2021 | 10:33 AM
jwsc's Avatar
jwsc
Where can you get new solenoids cheap? Because online it looks to be like 300$.
Old Jun 14, 2021 | 10:34 AM
jwsc's Avatar
jwsc
It had a major leak on the hard lines so I replaced them with rubber hosing and put all new dextron 6.
nodeal
Dec 21, 2018 03:40 PM
92400beast
May 17, 2018 05:47 PM
Njtrucker
Apr 17, 2018 06:34 AM
Rider
IS F (2008-2014)
18
Feb 5, 2012 05:34 AM
