Where does this plug into? (Non-VVTi 2JZGE)
Old Mar 13, 2021 | 10:09 AM
Crevasse's Avatar
Crevasse
Default Where does this plug into? (Non-VVTi 2JZGE)
I am just about finished with my NA-T build (using non-VVTi 2JZ GTE FFIM), wiring is the last thing that stands in the way before I can turn the car over. Despite my best attempts to document everything, I missed one plug and I have no idea where it goes. I have tried looking at wiring diagrams, searching keywords, feeling all around the engine block on the driver's side but I can't find anything. Searching "2 pin grey plug 2JZ" is so broad that I don't get any meaningful results here or on the internet in general.
For reference, this little 2-pin grey plug comes off the same harness "branch" as the ignitor and the power steering sensor plug and it's wrapped in the heat shield foam (circled in red):
If there's any additional info I can provide or other camera angles please let me know. Every other plug/sensor has been accounted for except for this one!
Thanks,
Crevasse
Old Mar 14, 2021 | 12:32 PM
Crevasse's Avatar
Crevasse
Solved; for those who care/have the same problem someday, this goes to the progressive power steering solenoid. The connector it plugs into hangs down from the underside of the rack/pinion assembly making it completely hidden from view when looking down into the engine bay.
Old Mar 14, 2021 | 12:50 PM
ISFFUN's Avatar
ISFFUN
I would like to know why my car doens't have that connector! I have the conenctor on the rack, but there's no wire to go to it from the harness.
Old Apr 23, 2021 | 03:21 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Only some SCs will have the connector on the harness, my 5spd 95 did not have it. if you are on the gte ecu you may want to leave it unplugged.
ColdFusion
IS F (2008-2014)
12
Mar 13, 2021 08:33 PM
joe diego
Mar 11, 2020 10:55 AM
meangreen1
Apr 22, 2010 07:59 PM
TopNotch
SC400 / 300 Classifieds
Nov 5, 2009 07:33 AM
