How can the AC evaporator be cleaned in place?
Old Jan 27, 2021 | 09:14 PM
MassOut's Avatar
MassOut
10th Gear
Default How can the AC evaporator be cleaned in place?
Hello,
Just wondering if anyone has any input on how to effectively clean the under-dash air conditioning evaporator (not the condenser) on a 1999 SC 300 without disassembling the HVAC housing?
When looking into the HVAC ducting with the cabin air filter access door removed and using a flashlight and mirror, the evaporator's finned core looks like it has significant cigarette ash or other contaminants embedded in its air inlet. My car did not have a cabin air filter in it when I purchased it.
Thanks.
Old Jan 30, 2021 | 05:45 PM
1997Soarer's Avatar
1997Soarer
You want the Toyota AC refresher kit
Available from any Toyota or Lexus dealership, or you can order it.
Part Number: 00289ACRKT
Supersession(s): 00289-ACRKT; 289ACRKT
  1. Designed to remove objectionable odors from the vehicle’s air conditioning system.
    • Genuine Toyota Power Foam Evaporator Cleaner and Refresher (Step 1).
    • Genuine Toyota Condition Air Automotive Ventilation System Refresher (Step 2).
  2. 2-part kit.
  3. Aerosol deodorizer for air intake vents.
  4. Freshens air conditioning intake and evaporator core.
  5. Expanding foam evaporator core cleaner and refresher.
https://parts.toyota.com/p/Toyota-AC...0289ACRKT.html
The previous owner of my IS300 smoked cigars in a tropical climate and no matter what I did, turning on the AC would make the car smell like cigars. The expanding cleaning foam works so well I didn't even need to use the spray deodorizer.
The hose sprays the expanding foam up the evaporator drain tube and it floods the evap core
jvangun
LX - 3rd Gen (2008-2021)
Jan 28, 2021 05:46 AM
aachowhan
Oct 13, 2019 07:53 AM
MNRambler
Aug 2, 2015 11:05 AM
artbuc
Jul 28, 2013 05:10 PM
juguryan
Mar 15, 2007 10:49 AM
