Throttle sticking at idle
Old Nov 28, 2020 | 05:45 PM
ObSCessed's Avatar
ObSCessed
Default Throttle sticking at idle
Hi guys, I am having a an intermitent throttle pedal sticking when I come to stop usually after higher speeds or after coming downhill. Feels like I have to press the gas harder to get it unstuck then its fine. I have no other pedal problems when moving only occasionally when stopped. I'm guessing it could be some carbon buildup on the butterfly valve and when it gets heated up it causes it to stick? Any ideas welcomed,thank you.
Old Nov 28, 2020 | 08:52 PM
Tallyhoe's Avatar
Tallyhoe
May want to trace your throttle cable and inspect it to ensure no debris is hanging on it or it isn't fraying. If its a no, then proceed in removing the intake tube and cleaning that throttle body. Should just do both at once, clean first and while it dries chase down the cable.
Old Nov 29, 2020 | 10:45 AM
ObSCessed's Avatar
ObSCessed
thank you, will try
st3v3
Nov 28, 2020 05:34 PM
Lukas99GS
Jan 12, 2014 03:28 PM
Gate
Maintenance
Oct 2, 2011 12:27 AM
aerosmith1
GS - 1st Gen (1993-1997)
Apr 18, 2010 01:34 PM
JonCAGS300
Dec 3, 2006 08:06 PM
