E85 Conversion?
Old May 2, 2019 | 02:29 PM
ssteffl's Avatar
ssteffl
Default E85 Conversion?
Hey all, I bought a 99 SC400 a couple months ago and have been working on replacing the rear subframe and brake system. One thing I wanted to know was if anyone has converted their SC to run on E85. There's a couple stations near me that offer it, and I believe that over the long run it would be cheaper than buying 93 premium. Any thoughts or opinions?
Old May 2, 2019 | 04:04 PM
gerrb's Avatar
gerrb
Super Moderator
Welcome to Clublexus.
To use E85 , too much stuff you would need to change. First your stock ecu won't work cause it is tuned for Pump 89-93. So you will have to use an aftermarket ECU. Your fuel lines are small,. E85 uses 35% more volume . And because of that , you will need a fuel pump that flows more . These are some of the things why there is no point of going E85 on a stock SC400.
Good Luck on whatever mods you will do on your SC400. Enjoy it !
Hintonjr
Jun 18, 2019 08:00 AM
g4ebguy90
Mar 26, 2012 01:34 AM
scweetfl02
Dec 28, 2011 09:12 AM
XxSC400xX
SC400 / 300 Classifieds
Oct 9, 2008 05:08 AM
One HoT
Feb 25, 2004 05:11 AM
