Suspension done
Theis is a before shoot
Cleaned up
Uca out of the way
All cleaned up and painted with a brush
Stock top hat with cut bump stop
Eibach tt with front stock shock! Front fits flawlessly!!
Removing front shocks couldn’t be any easier
I was working on my 97 sc last night installing ls400 bbk and I also wanted to install TT eibach springs. Guys it’s so so mush easier to loosen the top 3 nuts, then uca long bolt ( with 3 small 10mm bolts) to clear the plastic to pull the bolt out, and then shock bottom bolt in that sequence.
So after that was done I was able to mount the Supra eibach front spring onto the sc300 original tokico shock the front as your guys can see was spot on as far as fitment on the shock.
I haven’t installed it in the car yet, because I still have to replace the sway far for the tt and the end links.
Compared to the old school method removing the bottom shock bracket this was walk in the park.
as a matter of fact it was so easy I decided to clean, dry then paint the hub and lca!
Here are some shots from 1am
I was actually working on the ds late last night, noticed a torn brake line, thats next to replace and lost my caliper pin clips
I have a can of “car brite” black engine paint, I’ve had this can for over a decade sitting in my garage, I had to put this good stuff to use.
THMotor
Club Lexus Vendor Marketplace
Dec 1, 2016 02:53 PM
xboostx
Jan 4, 2012 08:58 AM
3rdelement
14
May 6, 2007 02:12 PM
