1996 SC400 260 HP - why?
Hi Frank,
I think this is because of a change in the ECU and also applies to 97. The engine wasn't redesigned until 98.
Whatever happen to the SC wheels you had for sale. What year SC are they from?
George
George
Originally posted by Carpe Diem
Hi Frank,
George
Hi Frank,
George
Actually, there were a few changes.
(the following numbers per Mitchell)
The 4.0 liter 1UZ-FE found in the 1990-1994 LS400 and the 1992-1995 SC400 had the following specs.
250hp @ 5600rpm
260tq @ 4400
10.0 : 1 compression ratio
The 4.0 liter 1UZ-FE found in the 1995-1997 LS400 and the 1996-1997 SC400 had the following specs.
260hp @ 5300rpm
270tq @ 4500
10.4 : 1 compression ratio
I am uncertain WHY Lexus didn't upgrade the 95 SC400 with the more powerful engine found in that years LS400.
Now, nearly a half a point more compression is a good start in making more power. Notice peak power happens 300rpm sooner and peak torque 100rpm later.
Also, the cam lift specs are different so apparently the camshafts are not the same.
I am uncertain about the SC400 but on the LS400 the exhaust system and the intake system was changed.
A further word: I personally believe the earlier engines are over-rated by 10-15hp. I gather this from both dyno testing and pictures of the factory engine dyno. Also, the improvement in acceleration on the 95 LS400 is better than you would expect compared to its very modest claimed 10hp increase. All things considered I would say the earlier engine is in reality 235hp and the 95 LS400 / 96 SC400 engine is accurate at 260hp.
250hp @ 5600rpm
260tq @ 4400
260hp @ 5300rpm
270tq @ 4500
Right on the money jbrady. The additional compression seems to be responsible for the bulk of the gain, the change in the ECU and cam profiles I believe are basically to take advantage of the higher CR. As to why Lexus waited a year before changing the SC, i'm told they wanted to debut it on the LS first, don't really see the logic in it either. Devin, don't bother trying to use the newer ECU.
zukikat
Apr 12, 2011 05:44 AM
redfusion
Jun 25, 2003 05:24 AM
