sway bar end link replacement???
Old Jul 17, 2003 | 12:46 AM
neagan's Avatar
neagan
Default sway bar end link replacement???
I just installed a fresh set of Tokico struts and did the Daizen sway bar bushings. I've noticed that there dosn't seem to be any discussion on replacing the factory sway bar end links.???? One of my fronts seems to be leaking grease and I'm wanting to know if I should go factory or????? By the way; I could REALLY feel the difference in the Daizen sway bar bushings even though my 95 is a lower mile unit. Thanks. Nitro
Old Jul 18, 2003 | 08:58 PM
DoubleWhoosh's Avatar
DoubleWhoosh
The stock links are a spherical joint link, so you can't get anything that will be stiffer. Just check if they have any play in them (not in a circular motion, but back and forth), the type of play that would cause clicking or rattling. If so, then they need to be changed. Let me know if you need some we have OEM stuff at pretty good pricing.
The only issue for removal would be that there is a high possibility that the inside stud will spin when trying to remove the nut. If there is any corrosion, it will be even worse. If you have ANY intention of taking them off or changing them, generously spray some liquid wrench or WD40 on them every day for a few days. This will make things a whole lot easier when you try to get them off.
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Old Jul 18, 2003 | 09:36 PM
neagan's Avatar
neagan
Hey Todd, thanks! I bought my bushings from you and like I said in the post, they are great! I'll check for the play and get back to you, especially since one of the front units is oozing grease. nicholas
hypervish
RX - 1st Gen (1999-2003)
Nov 22, 2014 09:42 AM
lexforlife
May 12, 2014 11:17 PM
JAB
Oct 30, 2013 07:05 AM
bags29
Jun 26, 2013 05:26 PM
GS714
Jan 24, 2012 03:08 AM
