Kyles SC400T Build
I pulled the oil pan to check the bottom end. There are chunks...
The crank is rusted. Turning the engine over makes the connecting rod knock chunks of rust off.
I've never seen this before, even on crankshafts I've pulled and left on the floor for 2-3 years. Maybe this is a flood damaged car. Either way, this engine is scrap, I'll part it out to try and recover some $. It was 400$ and had 50k miles on it. I bought the engine for the thicker early connecting rods, but new rods would have only been 600$. I don't want to gamble on another used engine.
I'm debating just replacing the cams in my engine, and leaving stock valve springs and rods in, however I think this would be pushing the rods close to the limit and I'm unsure about the stock springs with the higher lift cams. Some back of the envelope math suggests the stock thin connecting rods would survive up to ~470whp. I'll have to think about this for a while.
The next project will be figuring out why the rear brakes are not working
We found out at the dyno when I tried to ease the car down the ramps nose first. The front wheels locked while the rears did nothing. The car slid forwards with the ramps, landing on the floor, thankfully there was no damage
Shiny new rotors, EBC Yellow pads
Level10 Torque Converter, they said this will fix the high RPM slipping. I cant believe how fast they turned this around. I ordered it Monday night at 11pm, with the custom specs of my engine, and it showed up on Friday!
The plan is swap the torque converter this winter, and re-tune the car on oxygenated race gas to see if I can push it over 400 whp. I'll start the season like that, and buy another junkyard motor in March for a full out build.
I hope you found a better .location for the alternator (shown in 12/22 9:01 PM), or used a heat shield - way too close to the exhaust. Even another 1/2" will help.
https://www.clublexus.com/forums/bui...l#post10023146
