SC- 1st Gen (1992-2000)
Will a 95 flush mount spoiler mount on a 99 without mod
Old 08-13-17, 09:22 PM
roc
roc's Avatar
Default Will a 95 flush mount spoiler mount on a 99 without mod
Just bought a 99 sc,same color as my 95.getting ready to swap around parts.are the spoilers interchangeable
Old 08-14-17, 01:52 AM
- V -
- V -'s Avatar
if i remember correctly, i read in a post somewhere that the mounting holes or wiring holes for the brake light dont match up. The spoiler still covers them but you would need to drill new once for the swap. I would definitely double check this information though. Im going off of memory.
Old 08-14-17, 04:44 AM
roc
roc's Avatar
Thanks,my 99 spoiler has a brake light,95 flush mount spoiler doesn't.
Old 08-14-17, 07:29 AM
t2d2
t2d2's Avatar
You'd be better off swapping the entire trunk lids. Then you don't have to drill new holes and plug old ones. Water leaks in the trunk are annoying.
You'll probably need to swap lamp failure modules for the different spoiler setup. It's a little plastic box, located near the antenna, clipped to the outside of that shared brace. There are different ones for various years, some are for "with spoiler" and some are for without.
Old 08-14-17, 08:20 PM
Ramblerman
Ramblerman's Avatar
The 2 outside mount holes on 97+ are the same as the older models but 96 and older spoilers have more mount holes inboard of those. There is also a seal that that is 4 pcs that goes under the older spoilers. I have been told that the older spoiler can be mounted to the newer trunk lid just by using the 97+ mounting holes. I will see, as I have a 97+ trunk lid that I will be putting my 96 spoiler on to replace the bad trunk lid on my 96. Use silicon where needed to help with sealing.
Old 08-14-17, 09:19 PM
Teal Sc400
Teal Sc400's Avatar
Then its not a 95' spoiler, if it doesn't have a brake light and may not matter?
Old 08-16-17, 10:55 AM
salimshah
salimshah's Avatar
And dont forget about the counter weight spring tension as the weight changes due to spoiler.
Salim
slow2jz
11-29-18 09:12 AM
Remix919
05-18-14 11:41 AM
vinster29
RX - 1st Gen (1999-2003)
01-07-04 04:08 AM
flossn
11-12-02 08:26 PM
satxrx
11-19-01 08:00 PM
Quick Reply: Will a 95 flush mount spoiler mount on a 99 without mod
