1995 sc300 1jz swap issue?
Old Jul 12, 2017 | 08:31 PM
Codyg1jz's Avatar
Codyg1jz
Default 1995 sc300 1jz swap issue?
Its hard to find active threads about some issues that im having any help would be great.
Car is a 1995 sc300 1jz soarer swap
I have the problem where the car cranks when connected to the battery. I cant find any information on where the push button or switch is ran from. Also what is the 12 v fuel thing that ive read about? Seems like some people do it and others dont. Also what ground wires are in the engine bay the one up on the back of the head one under intake to chassis and then the ground from battery to bell housing?
Old Jul 13, 2017 | 05:03 AM
kez's Avatar
kez
https://www.clublexus.com/forums/per...ue-solved.html
i just did this on my second swap
Old Jul 13, 2017 | 10:49 AM
Codyg1jz's Avatar
Codyg1jz
Originally Posted by kez
Thanks i will do this this weekend when i try to start again. I think i fried my seleniod on the starter cause i cant get it to crank when bench testing. Im gonna pull the starter off the 2jzge and try it.
as for grounds in the bay, How many are there and located?
Old Jul 15, 2017 | 10:02 PM
Codyg1jz's Avatar
Codyg1jz
Ok i got the starter issue figured out now. But now im not getting any spark!! I have fuel i can smell it on the plug.
After doing some forum searching i found to check the crank position sensor And grounds, all grounds are tight. Where else should i be looking if resistance is in spec on crank postion sensor?
RekkSoarer
Aug 11, 2010 06:35 AM
schef300
Jun 11, 2010 07:16 PM
rustednail
Pacific
Jun 1, 2010 09:58 PM
soarer NAT
Oct 29, 2004 07:55 PM
