Climate Control LCD Bulb cap
Does anyone know what size bulb cap is used on the bulbs for the LCD screen on the climate control? ie. are they the same size as the caps for the transmission selector caps or maybe even the ECT switch bulb cap?
Front rear Defrost, circulation and Ac bulb is a t5 neo wedge
Indicator lights are 3mm LEDs (any size will do just soder in)
And for the LCD and bulb can be used just soder it in.
By the way for your cluster you will need 74 bulbs
Hi, Tanin Auto Electronix here. We are vendors on the site and want to offer this repair out to you in case you decide to go that route:
http://www.taninautoelectronix.com/1...ate_repair.htm
Let us know if you have any questions. Happy to help when we can!
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
https://taninjdm.com/ Our Lexus LS430 Dealership
262-456-4147
https://youtu.be/2LtbYfZ8rig
I appreciate the response but all i'm looking for is the size of the blue bulb caps. All my lighting works as it was repaired sometime ago however I believe whoever made the repair forgot to place the caps back on the bulbs behind the LCD screen. I was curious to know what size they are and if they also fit on any other bulb found in the car...as I can order most of the caps from the dealer if I can find the one that fits.
This is perfect. Thank you.
i'm happy to see that you found your answere
John U
Dec 15, 2008 05:24 PM
