steering shaft question!?!?!
just did the rack in my 97 sc300. when i was putting the new one in i had a friend trun the wheel over an over again (prob like 15 times) while i was searching for the bolt hole because im blind and cant she where it exits. the shaft was completely disengaged from the rack and started to make a small rubbing noise. i told my brother about it in the morning and he freaked out an said it can ruin the steering column?????? really? he said that it would destroy his jeep if he did that but he wasn't sure about my car. i just wana know if im going to be driving down the road one day and i end up in a wall or something..... any one know any thing about this or is he just blowing smoke?
The spiral spring must be toast by now.
One of the greatest things this Forum does is educate the DiYers. Search and read through all the posts and then tackle the job. Before replacing the rack, I used the driver seat belt to loop through the steering wheel to prevent it from spinning. You can unbind the coupler (from both ends) and simply slide it up and down to connect the column to the rack.
Salim
Salim
Salim
Salim
manalive20
Suspension and Brakes
Apr 10, 2007 10:09 AM
