Speedometer mismatch
Old Oct 11, 2016 | 05:12 PM
lochone112's Avatar
lochone112
Default Speedometer mismatch
Question I've begun swapping from auto to manual. With the stock w58 from a 94 sc300 into a 99 sc300. Only problem so far is speedometer cables do not match. Does anybody have a remedy to this?
Old Oct 12, 2016 | 02:41 AM
KahnBB6's Avatar
KahnBB6
SC300's of all years and the '94 SC300 W58 you have do not use speedometer cables. The cluster input uses a three-wire Vehicle Speed Sensor (VSS) connection and the transmission has such a sensor on its side. I'm not sure what cables you are looking at?
Aside, if you want to make your speedometer perfectly accurate after noticing it is off, you can buy a Yellowbox V4 speedo corrector and an SC/MKIV specific PnP harness from Yellr. You'd calibrate it by referencing a GPS.
Old Oct 12, 2016 | 09:56 AM
lochone112's Avatar
lochone112
The manual I have is a 2 wire....
Old Oct 12, 2016 | 11:45 PM
KahnBB6's Avatar
KahnBB6
I've never heard of that on an SC300 W58. Can you shoot us pictures of the sensor location on your W58 transmission?
Regarding the swap overall, have you looked up W58 into 98 SC300 swap threads by Cartmill? He completed the same swap successfully and it would be good to reference in your build.
aristotrey
Mar 13, 2016 11:09 PM
chowda
Jan 17, 2015 10:34 PM
drastiq619
Oct 2, 2014 04:02 AM
InLyneTrbo
Aug 6, 2011 02:00 PM
got-sc?
Dec 9, 2009 11:09 AM
