Used tranny
Old Apr 25, 2016 | 05:56 PM
Cthopkinsc's Avatar
Cthopkinsc
Default Used tranny
Recently put in low mileage used tranny in 1995 sc400. Had tranny fluid changed and filter cleaned. Everything looked and worked good for a short time, then it began to take a long time to shift from park to drive;especially with the engine cold. What could be the problem? If this one(tranny) is toast, where can I find a decent used or re-man?
- Thanks In Advance
The Hop Man
Old Apr 25, 2016 | 06:52 PM
javaswing's Avatar
javaswing
- Thanks In Advance
The Hop Man
there is an host of things that could be wrong, does it make an whinning sound when cold? need more info.
Old Apr 26, 2016 | 01:27 PM
Cthopkinsc's Avatar
Cthopkinsc
No. Not at all. Once it goes into gear, it doesn't overheat or slip like the previous one
Old Apr 27, 2016 | 06:38 PM
javaswing's Avatar
javaswing
can you check pressure on the fluid?
Old Apr 29, 2016 | 04:14 PM
Cthopkinsc's Avatar
Cthopkinsc
How do I go about that?
Old May 17, 2016 | 01:52 PM
Cthopkinsc's Avatar
Cthopkinsc
Default Used Tranny Again
CT here. Recently had the pan, gasket and filter replaced. Everything looked pretty darned good. So now I'm really scratching my head. It still takes a loooonnng time to go into gear. The car has to idle at least half-hour before any forward motion happens. So I took it to a shop. The mechanics there offered me a pretty decent deal on installing Rostra Controls shift solenoids. Are we on the right track?
sbtots
RX - 1st Gen (1999-2003)
27
Sep 27, 2018 04:09 PM
ShaneC
Performance
Jul 2, 2007 01:49 AM
resen323
GS - 1st Gen (1993-1997)
14
Apr 22, 2007 10:59 AM
SCmist
Aug 20, 2003 08:01 PM
mrshabo
Jul 9, 2003 07:10 PM
