Need Help!!!!!!!2jzgte acting up
Old Oct 15, 2015 | 09:30 PM
scmaluco's Avatar
scmaluco
Originally Posted by CatManD3W
When I pulled out the old plugs over the weekend they were so fouled up...
Keep in mind these plugs were in for less than 500 miles...
Have you checked and tried to adjust your tps? Sounds like it could be the tps..
Old Oct 19, 2015 | 04:20 PM
CatManD3W's Avatar
CatManD3W
So I kept checking the car daily and as of last week it is back to normal.....the only thing that I had done different was add some lucas fuel treatment....I cant see how bad gas would of caused all this but that may have been it....
The car has a normal idle.....I can rev the car all the way to redline.....and my AFR is normal all the way to redline....
I replaced the o2 sensor with a new one today....and I am still awaiting my new TPS to get here from Toyota...
I have not yet driven the car......I plan on taking it out tomorrow for a drive....will update with what I find out
Old Oct 20, 2015 | 01:54 PM
CatManD3W's Avatar
CatManD3W
Well guys took it for a drive today and all is good......Not sure what the cause of the problem was but it has appeared to fix itself
Old Oct 21, 2015 | 02:18 AM
gerrb's Avatar
gerrb
Super Moderator
The ECU I sent you was a MAGIC ecu .. it solved the problem...ahahahahhahahahahha
Old Oct 21, 2015 | 10:28 AM
CatManD3W's Avatar
CatManD3W
Yea Gerry....im going to switch back over to the JDM 6spd ECU and try it out and see if in fact it is the ECU
Old Oct 26, 2015 | 02:35 PM
CatManD3W's Avatar
CatManD3W
So i switched back over to the 6psd ecu just to check it and it made my car run terrible again....
And Swapped back over to the Aristo after I had grounded the system out..
Now all of a sudden the car will not crank over....I have fuel but no spark...
Im thinking it could be the crank position sensor...
Old Oct 28, 2015 | 05:55 PM
CatManD3W's Avatar
CatManD3W
Any one else have any thoughts opinions....im ordering a new crank position sensor and coolant temp sensor....
mattro2
Apr 30, 2019 12:02 AM
paul1012
Sep 10, 2015 02:57 PM
Harmless
Mar 4, 2015 03:42 PM
NoLongerA13bFan
Aug 6, 2009 05:52 AM
gdc5ind
Dec 16, 2008 08:26 PM
