Gauge placement/interior question
Old Sep 18, 2015 | 04:37 AM
Studiogeek's Avatar
Studiogeek
Question
Originally Posted by Ali SC3
its my fav feature, even when it kills my battery in the winter =)
That one move before starting kills your battery? Wow! Is something wrong?
Old Sep 18, 2015 | 07:24 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
yeah it did it for a while before I figured out the relocated battery wire has a few connections that tend to make worse connections over time since they were just crimped, and was apparently draining it so that the first move of the seat or steering wheel would drain whatever little was is left. re-crimped the connections but need to solder them up sometime, but the problem went away. was bothering me for like 1 1/2 years before I figured it out, I dont drive it that much really you can imagine. the issue is the wire is so thick that even if you get a good crimp I think the vibrations loose it up over time, so yeah another thing to learn/look out for.
Old Sep 19, 2015 | 12:37 PM
Studiogeek's Avatar
Studiogeek
Duly Noted..
Thanks!
Old Dec 17, 2015 | 01:46 PM
tjmhillz's Avatar
tjmhillz
Originally Posted by Studiogeek
Luckily, that is just the volt gauge in my 400. I went with 2 pillar and 1 on dash and SAFC in usual spot on the 300.
The third pillar pod did not work out for some reason so we put it on the dash.
Alisc3 spot is great as well!
Bumping this up. trying to see where everybody put their gauges. Also how come the 3 pod gauge didnt work on the pillar? also which pod are you using?
Old Dec 17, 2015 | 04:16 PM
Kris9884's Avatar
Kris9884
Originally Posted by CatManD3W
Here is how I did mine...
I'm sure the wires and hoses look better now but this is my favorite!
sj408
Sep 5, 2013 02:57 PM
craaaazzy
May 20, 2009 04:40 PM
Faraaz23
Automotive Care & Detailing
Nov 9, 2004 08:24 PM
SC30097
Feb 27, 2004 03:29 PM
