power window relay.....
Old Aug 19, 2015 | 07:20 PM
brett14's Avatar
brett14
Default power window relay.....
I am on a mission trying to figure out why my power windows or my sunroof do not work.
fuses were good
regulator gets power
no wires are broken between the door jambs
decided to check the fuses by the drivers kick panel again and i saw something missing. a relay. pretty sure its the power window relay
but my issue is every relay ive found has male prongs and in the pic youll see i need female prongs
did something break off in there? i tried pulling on the prongs and they didnt move.
any help would be appreciated thanks
Old Aug 19, 2015 | 07:41 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Did you rule out the master switch(es)?
Old Aug 20, 2015 | 04:52 AM
gerrb's Avatar
gerrb
Super Moderator
Brett - when you say regulators get power , do the windows go up and down when you apply direct voltage to the window motors ? At least that will rule out good or bad window motors.
If you have good window motors, they won't work through the switch because of that relay missing on your picture. That is the relay that provides power to :
1D pin 9 which provides voltage to the driver's master switch
1J pin 2 which provides voltage to the passenger window switch
IF pin 5 which provides voltage to the moonroof control
That should explain why your windows and moonroof do not work through the switches. Looks like someone had damaged the connector on that area. That should be a female connector , not male prongs exposed just like pictured. The picture clearly shows the damaged housing base of the socket. They tried prying the relay but instead pried the housing too, thereby damaging it.
Old Aug 20, 2015 | 05:47 AM
gerrb's Avatar
gerrb
Super Moderator
Brett - just send me text messages , I won't have much time to be on the forum today
on this picture , you see the base of the female socket they broke
this is the relay
Old Nov 10, 2016 | 01:20 PM
pjarvis's Avatar
pjarvis
Has anyone had any luck testing one of these with a multi meter?
jmatthorn
GX - 1st Gen (2003-2009)
Apr 28, 2016 05:08 PM
Jboswald
Jan 30, 2013 04:07 PM
sj408
Apr 8, 2009 09:31 AM
redsc400
May 31, 2008 12:37 PM
