MPG questions for higher efficiency
Old Oct 8, 2015 | 02:57 PM
t2d2's Avatar
t2d2
It only jumped out at me as odd because mine is so mellow on the highway, just purring along like a happy cat. (Gotta get in that "big cat" reference!)
Old Oct 9, 2015 | 12:37 PM
KahnBB6's Avatar
KahnBB6
^^ 1UZ V8's are one of the best long haul cruising engines.
I'm not sure what the rear ratio is on a 1998-2000 LS400 but I've driven one of those a lot and revs on the highway at 70mph were a lot less than 2800. More like 2100-2200 at most if I am recalling accurately.
Matguy, good luck getting your SC400 back together!
Old Oct 25, 2015 | 01:39 PM
matguy's Avatar
matguy
Yup, you're right. I don't know what I was thinking.
My math puts 70MPH at about 2250RPM. I still think it could use some lowering, but not as bad as I was thinking.
And thanks for the well wishes. Went back together OK.
Old Oct 26, 2015 | 12:40 AM
KahnBB6's Avatar
KahnBB6
Good news, then!
I don't think there is a lower ratio than 3.266:1 for the 200mm diff. I can't imagine it being much lower with only five gears in the 98-00 cars.
Old Oct 26, 2015 | 12:44 PM
matguy's Avatar
matguy
Oh, and this morning I noticed that I was wrong yesterday. I wasn't noticing the hash marks on the tach were 1/4 of 1000 and not 1/10. So, at 65MPH it was around 2250 (not 2100) which puts 70MPH just over 2400RPM, which it was this morning.
Old Oct 27, 2015 | 10:49 PM
KahnBB6's Avatar
KahnBB6
Hmm. The final drive in a 98-00 LS400 must be lower than the 3.26 in that case. I didn't look closely at your picture that evening either.
It would make sense that the SC400 with the same drivetrain would have a more aggressive FD though.
Old Oct 27, 2015 | 11:14 PM
t2d2's Avatar
t2d2
^ I've read that the LS400 is geared for better highway economy.
Old Oct 27, 2015 | 11:20 PM
matguy's Avatar
matguy
Hmmm... *scratches chin*
If the transmission has a wider range of ratios... well, to be realistic, it's not like I'm going to do a tranny swap just to get slightly better mileage. I'll just complain about it from time to time.
Old Oct 29, 2015 | 03:00 AM
KahnBB6's Avatar
KahnBB6
Well both the '98-2000 LS400 and '98-2000 SC400 use the same version of the 1UZ and the same heavy duty version of the A650 5-speed automatic. It's probably just the ECU's and rear ends that account for the differences.
superdenso
Aug 10, 2021 06:50 AM
danyeru
GS - 1st Gen (1993-1997)
14
Apr 8, 2014 08:00 PM
Torii
Jul 18, 2008 03:44 PM
sirkfc
Jan 24, 2008 04:54 PM
lexusnutt
18
Dec 15, 2007 01:58 PM
