a/f ratio chart
Old Mar 27, 2003 | 11:01 PM
808state's Avatar
808state
Default a/f ratio chart
anybody have a chart with voltage from an o2 to a corresponding air/fuel ratio? possibly a formula though it doesn't seem to be linear. i've found this on the web but was wondering if anyone has one with more o2 to a/f ratio readings?
Attached Thumbnails a/f ratio chart-af.jpg
Old Mar 28, 2003 | 08:36 AM
SC300T's Avatar
SC300T
You're absolutely correct, its nowhere near linear. Depending on EGT, your voltage will also fluctuate at a different rate as you move away from stoich (14.7:1). Another variable is that all 02 sensors don't have the same curve. They're all pretty much the same at 14.7:1, but have different rates outside of this range. Unless you have a wideband 02 sensor, you can't accurately tell the difference between a 10.5:1 and a 11:1 ratio.
Bumbobee
Oct 22, 2022 10:29 AM
Defratos
IS F (2008-2014)
Nov 4, 2016 08:29 AM
jcorredor
RX - 1st Gen (1999-2003)
21
Jul 14, 2008 11:08 AM
Anthracite SC
Oct 6, 2003 09:11 PM
