HELP!!!- (check engine light)
Old Mar 25, 2003 | 07:50 PM
RobSoVIP's Avatar
RobSoVIP
Default HELP!!!- (check engine light)
alright, so I was installing my RMM intake, I get everything hooked up, forget to plug in my MAF adaptor, try and start the car, it wont start (DUH) plug it in, get the car started... check engine light on... So whats the deal? is the ECU just acting wierd becuase its getting more air than normal should I reset my ECU?... help me! lol
also-my hood supports are gone, anyone want to tell me a place to get them, lol (no I HAVE NOT SEARCHED IT YET, lol...) but Im more woried about the first ?.
Thanks-Rob
Old Mar 25, 2003 | 08:06 PM
asnatlas's Avatar
asnatlas
Default Yes...
Since you added you intake you need to reset your ECU, You can pull your battery cable off for a few min and you should be fine........ And about your hood supports you sould be able to go to like Auto Zone or your local auto parts store and get a pair for like 60 or so I would think...........
Hope this helps
Shawn
Old Mar 25, 2003 | 08:52 PM
strongsail's Avatar
strongsail
trying to start just once with the maf sensor disconnected caused the ecu to store a fault code, the light will stay on until you clear the code, a full ecu reset should do it.
simplecar
RX - 1st Gen (1999-2003)
Jun 25, 2019 04:59 PM
Nosebleed
May 31, 2013 04:36 PM
NSeagle78
Maintenance
Jul 2, 2011 08:13 AM
hkykat
Nov 6, 2007 05:51 AM
bluelex
Performance
Feb 24, 2003 07:47 PM
