Need help with w58 shifter issue
Old Mar 27, 2015 | 01:59 PM
187's Avatar
187
Default Need help with w58 shifter issue
If anyone is familiar with this issue please let me know I haven't been able to find any answer specific to our transmission.
Here is what I am experiencing. Clutch all the way in try to put the shifter into first and I hit a kind of invisible wall where it gets caught for about 1 second then eventually falls into place if you keep steady pressure on it. Same thing in second but not as bad. BUT here is where I noticed if I try this with second on flat ground the car will move slightly forward when I pas through this wall of sorts.
I have tried adjusting the clutch with no luck, the issue remained constant as if it is independent of it. Also I did try testing it by revving it up in first in neutral with no outcome. It is only when you get into the "gate" area where it grabs or something.
Anyone have this issue or a solution?
Old Mar 28, 2015 | 07:00 PM
k7q's Avatar
k7q
I think I had this problem when i was swapping my 400. i had to adjust the clutch pedal a little more.
maybe adjust more and bleed it again? check the slave also.
Old Mar 29, 2015 | 05:58 AM
187's Avatar
187
I'll be checking the slave today, and the pedal is pretty much maxed out. The system was never opened when I did the new clutch so it was never bled.
Old Apr 10, 2015 | 05:42 AM
187's Avatar
187
Looking for any suggestions with this issue as i plan on getting under there today and tomorrow. Im not sure if i can do anything without taking the trans out but I'm open to suggestions.
Old Apr 12, 2015 | 11:09 AM
187's Avatar
187
Just to report back if anyone has this issue with the tripod 95-97 style w58 shifter, I fixed the issue by adjusting the piece under the shifter that links the tarns to the shifter. It's 2 12mm bolts. I believe it was tightened before the trans was put back into the car and was just misaligned.
/Aerostar\
Sep 21, 2015 06:45 PM
diss7
Performance
Jul 29, 2014 08:35 AM
96sc
SC400 / 300 Classifieds
12
Feb 20, 2012 02:43 AM
SOLID300
Jul 11, 2011 03:56 AM
Fuzzie
Jun 24, 2010 09:28 PM
