No Start No Spark ..Please Help
Old May 4, 2015 | 07:31 PM
marclub's Avatar
marclub
Default WOW What A Journey!! Finally Running!
Just wanted to update the status on this vehicle and let others know about the conclusion as to what the problem was. I had the computer repaired by Tannin Auto and still had no voltage at ECM at IGSW terminal. Thanks to Jonny Hoppman I was able to trace the wire back to a fuse box in the lower driver's side kick panel. I had previously checked the fuses with a multimeter for continuity they all checked OK. However this time I actually pulled them and re-inserted them especially paying attention to the one labeled "Ignition switch". Well after that I had 12 volts at the ECM IGSW terminal and guess what? It Started right up! So I guess it was a loose fuse. Thats IT! Maybe the computer needed rebuilding anyway...who knows?
Anyway, I can't say "thank you" too many times for Jonny Hoppman's assistance. Can't say much else positive about the response rate on this site. But it turned out good.
I can't stand it when you read about others posting here for help and they either don't get help or themselves don't let others know what the final resolution was. I'm doing my part.
Thank you Jonny!!!![/SIZE]
Old May 4, 2015 | 07:50 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
No problem, that is what forums are for! Glad to hear you got it fixed.
Personally, I have never heard an issue like this resolved by a loose fuse, thanks for letting us all know, it does help a ton in the future.
jetskiwill
IS - 1st Gen (2001-2005)
Dec 2, 2013 11:55 AM
anu7898
Aug 18, 2013 09:55 PM
GS3soulja
Oct 10, 2009 03:31 PM
Tyke
Sep 8, 2008 04:36 PM
SweetGS300
Sep 21, 2007 11:26 PM
