Limp home mode troubleshooting?
I have an odd problem that I need some expert assistance with. My SC400 idle is irratic and surges uncontrollably (undrivable). I found that if I disconnect the air sensor -it is driveable. I am guessing this is because this puts it in limp home mode. So if this is the case -and having swapped the IAC, fuel pressure regulator, spark plugs/wires, air sensor and EGR valve -what can cause it to surge like this and then run good in the limp home mode with the air sensor disconnected? Can the ECU cause a problem like this?
Anyone else ever have a problem like this?
Markysc4
Apr 17, 2013 11:41 PM
Lexstacy40
Jan 2, 2009 02:19 PM
