Head gasket recommendation
Old Nov 14, 2014 | 08:53 PM
jsimms2's Avatar
jsimms2
Default Head gasket recommendation
head gasket on my wife's 95 sc300 has decided to start pissing coolant. Any recommendation on which head gasket kit to go with as far as replacement? everything is stock. I was thinking FelPro since it is in stock locally but I wasn't sure if they are garbage for this car. Any recommendation is appreciated.
Old Nov 14, 2014 | 10:11 PM
CatManD3W's Avatar
CatManD3W
If you have to replace the headgasket......might as well get either a OEM 2jzge or 2jzgte headgasket.....and do ARP headstuds at the same time since the head will be off
Old Nov 19, 2014 | 11:47 PM
soarer13oy's Avatar
soarer13oy
Go with oem head gasket with the arp head studs. Use your oem washers fromt he head bolts.
MacGyverQu
May 29, 2014 08:12 AM
B1TEM3
Nov 23, 2013 05:44 AM
supraclay
Jan 30, 2012 07:12 PM
