OK, another W58 into SC400 question
Old Nov 10, 2014 | 07:58 PM
sc4hunnit's Avatar
sc4hunnit
Default OK, another W58 into SC400 question
ok, I've got it down pat for the most part, sc300 pedal assembly, blah blah, sc300 manual driveshaft, yadee--ya, adapter kit from 1uzfeswapkit.com
now, my question is, I have a W58 out of an MK3. Was told the shifter doesn't work so I'll need one from an sc300 w58. Is that true? do i need to do any cutting or jerry rigging? I've seen so many different types of kits for this swap. I've seen some people have nightmares and some people saying it's super easy.
More info on my car, 95 c400. Any and all help would be greatly appreciated!
Old Nov 10, 2014 | 08:35 PM
3L4jzz31's Avatar
3L4jzz31
CL Folding 10,000
w58 from mk3 shifter is too short, it needs to be extended to work
Old Nov 11, 2014 | 10:27 AM
maynanator's Avatar
maynanator
You'd be better off just having the shifter extended then trying to find an sc300 shifter.
Old Nov 13, 2014 | 05:56 PM
sc4hunnit's Avatar
sc4hunnit
Extended how? couldn't I use the shift chair from an actual sc300 manual transmission
Old Nov 13, 2014 | 11:59 PM
CIGLexus's Avatar
CIGLexus
I was able to convert a JZ W58 to work in an MK2 Supra. I had to change the linkage and also grind a little bit of the internal shift connections.
Given that, you may be able to convert an MK3 to JZ, just do the reverse.
Old Nov 15, 2014 | 12:59 PM
3L4jzz31's Avatar
3L4jzz31
CL Folding 10,000
You can use the sc300 95-97 (tripod style) or mkiv (tripod as well) w58 external shifter assembly on your w58. as these are usually difficult to get a hold of because most people don't want to seperate them from the tranny, people who do not wish to wait/search for this piece go along the method of extending the shifter assembly as seen done often on the r154
ThompsonSC
May 21, 2022 08:15 AM
scfou
Feb 12, 2016 05:31 PM
Gspec
Apr 6, 2013 02:45 PM
xspsi6
Aug 10, 2011 12:54 PM
