Why does our EFI relay get hot?
Old Sep 14, 2014 | 09:26 AM
bigwhite's Avatar
bigwhite
Default Why does our EFI relay get hot?
I had recently been reading through some prev. post concerning fuel pump issues, and a member said his EFI relay would be so hot it would burn his fingertips. The first time I checked this, my car had set for a few minutes, and I had to unscrew the fusebox cover. I checked and it was warm but not really hot. Then I had an issue that I needed to unplug my relay after a 20 min. drive, while it was still running, and it did burn my fingers. This is with a new EFI relay. I new they are metal jacketed, im guessing to dissipate heat, but this seems abnormal?
Old Sep 14, 2014 | 09:57 AM
t2d2's Avatar
t2d2
Mine is like that, too. Good thing I added the resistor to my EGR delete and hopefully won't have to pull it anymore to reset the CEL! (The EFI 30A fuse would probably suffice.)
Old Sep 14, 2014 | 09:40 PM
oldManTan's Avatar
oldManTan
doesn't unplugging the battery simply reset the ECU? that's wat i usually do, but i guess if you don't have a 10mm with you makes sense to pull the fuse. i got a toolbox in my trunk so i've never pulled that fuse.
Old Sep 14, 2014 | 09:51 PM
t2d2's Avatar
t2d2
That method also resets radio and seat/steering wheel memory.
Yours is 10mm? Mine is 13mm.
Old Sep 27, 2014 | 12:19 PM
bigwhite's Avatar
bigwhite
Hoping that if I bump this thread someone will see it that knows the answer. My car is not turning off until you pull the EFI relay and I have replaced it and also a new ig. switch and ig. relay.
Raisin
Mar 14, 2018 06:20 PM
JKBHEAT
Jan 24, 2017 11:54 AM
Performance
29
Sep 10, 2016 01:18 PM
berumene
Performance
Aug 28, 2015 06:53 PM
e-man
Mar 15, 2006 08:26 PM
