Bushings ?
Alright,so on my way to work,I was going into a sharp corner when my 400's rear wheels buckled over. Went home & looked & found some blown bushings. Need to know what they're for since im not too wise with suspension haha. One is linked to the botton of the shocks & the other to the brakes.
That is the rear strut rod, very easy to replace and can be found at junk yards. Only problem is when the bushings are seized to the actual bolts. You might want to heat them up with a torch to remove them better. If you cant find one local, contact Aliga on here or R&J. They might have them.
