Few engine swap question need answer fast
I have done a complete 1jzgte engine swap and need some clear answers.
1 I the engine has a single turbo should I change the fuel pump? turbo is a t70. walbro or something else.
2 Does the sc300 radiator work well with this swap? my after market thermostat is creep pass 220 degrees it when running it. at idea stay below 220 degrees.
3 Searched and found a koyo radiator on driftmotion have any put on there car any issue? saw a aftermarket aluminum on ebay as well driftmotion cheap, ebay expensive
4 should I buy toyota radiator coolant the pink kind or something else?
5 I have electric fans on my stock sc radiator should go back to clutch fan when If I buy the aftermarket radiator? if I do gonna need to buy a fan and fan shroud
need answer as soon a possible gonna start shopping Friday thank you
1) yes denso tt or walboro.
2) sc300 radiator works just fine. there is probably an issue with yours.
3) many have gone aftermarket radiators, need to mount it and stuff but its straight forward.
4) everyone says different but I use the toyota red and dilute it myself.
5) stock clutch fan is the most reliable and cools perfect. electric fans are alright some are good some are much worse than stock so that is up to you. I wouldn't run universal fans on these motors I would use the stock clutch fan setup or an electric fan setup from an IS300 or something like that.
