Hey Guys,
i am in the (long) process of installing a 1jz gte vvti in my 92 sc400, and in removing the sc400 fuel line, i kinked the fuel hose slightly, in fact i can't get the sc400 line to un bolt as it is slightly bigger than the SC300 one on the banjo bolt end.
as you can see i ****ed the line a bit, it twisted. i imagine my next choice is to use some pipe cutters and cleanly cut off the damaged part of the fuel line, and crimp on some fitting. what are my options here? another hardline from an sc300/400? thanks for any pointers / parts solutions to this.
cheers
Marko
cheers
Marko
Easy fix. Either get a 300 fuel line and replace it with that. Or rent a flare tool, cut that off behind the kink, and source the correct sized fitting, re-flare the end and install.
OR, contact Aliga.
OR, contact Aliga.
