Full suspension refresh
Old Oct 3, 2013 | 11:06 PM
9600baud's Avatar
9600baud
Default Full suspension refresh
So my 92' with 250k miles squeaks every time I go over a bump. It started in the front now the back, sounds just like those "old car squeaks" so I want to do a full suspension refresh.
I already have front LCAs in the plans, but I want to swap everything for new ones. What should I look for? I'm not too familiar with the suspension geometry and what I should replace.
Should I get new wheel hubs too?
Thanks!
Old Oct 4, 2013 | 03:20 AM
Slaker13's Avatar
Slaker13
Having same issue, can't stand those squeaks! Only difference is I have a 95'
Old Oct 4, 2013 | 05:28 AM
bmxkeeler's Avatar
bmxkeeler
Start with the basics. Control arms and bushing, check tie rod ends, struts, springs, strut mounts. Give your motor mounts a look over and make sure they're all in acceptable working order. Replace your sway bar links.
I wouldn't be too concerned with your hubs. You can jack up each individual wheel and see if the bearing has any play. if it doesn't I wouldn't worry.
Old Oct 5, 2013 | 02:02 AM
9600baud's Avatar
9600baud
Thanks I'll make a shopping list and post the results.
Old Oct 5, 2013 | 11:12 AM
9600baud's Avatar
9600baud
Hi,
I see front lower bushings, I thought the front lower bushings couldnt be changed and a whole new arm needed to be bought?
Thanks!
Old Oct 5, 2013 | 04:13 PM
Answer300's Avatar
Answer300
no you can get all new bushings for the front LCA's. as long as the structure of the arm is okay then just press in new ones. they have arms from Ikeya Formula but they're damn expensive. im sure BV will come out with something in the future but so im holding tight for those
deadguy
Jul 29, 2024 12:22 PM
pbxcomm
Suspension
Dec 5, 2018 04:02 AM
Fojo
Nov 21, 2015 08:00 PM
Bumbobee
Apr 10, 2014 01:50 PM
Ariyanna
Feb 8, 2007 09:59 PM
