Since I rebuilt my ECU with new caps not only did overall driving performance improve
significantly but gas usage went from 17 to 22.8 MPG with A/C running. This is in town
driving.
The strong gas odor from exhaust disappeared and I noticed my idle speed at stop
is lower but very smooth...more like 500 RPM. Don't know whether the higher rated caps
that I used to replace the old ones could possibly make the car more efficient than when new
but I don't ever remember getting in-town MPG any better than 21
I just sent mine to get repaired. I should get my comp back by tomorrow or monday. Im so excited cause I havent had my car for 2 months. My mpg was 17 so I hope it goes up too.
Good luck. I could not beleive the overall improvement in performance after the rebuild.
driving.
My car is a 1993 SC400 with 90K miles.
Hey where InFlorida are you located I'm in Orlando and need my ecu rebuilt. Can you pm me your contact info?
I might have my ECU rebuilt just because it probably needs it and the ECU has 150k on it. Sorry, but ho much did this cost you?
slide ...read the posts in the "weird idling problems" thread and you will see the details of how i went about rebuilding my ecu. also, make sure u read cowboy's write up on this whole issue. the web address is in post 21.
cost....$10 for caps and $50 labor done by a tv service man who was a friend of mine. normal service charge would prob be triple.
brian..as i mentioned to slide, read the posts in the "weird idling problems" thread and you will see the details of how i went about rebuilding my ecu. also, make sure u read cowboy's write up on this whole issue. his web address is in post 21.
i live in pensacola and it gets just as hot here as orlando. almost always after my car sat in the sun for an hour or so, it would srart rough and run very poorly. that was my biggest clue to bad caps which tend to really break down when hot.
