2jz question
Old Jul 11, 2013 | 12:15 PM
SSRsp1SC's Avatar
SSRsp1SC
Default 2jz question
the 2jzge vvti shortblock is it the same shortblock that the 2jzge NO-vvti ? i want to do a 1.5jz with a 2jzge vvti ..
Old Jul 11, 2013 | 05:42 PM
2jznosht's Avatar
2jznosht
Are you asking if you can put the vvti head on the normal ge short block?
Old Jul 11, 2013 | 06:34 PM
SSRsp1SC's Avatar
SSRsp1SC
No , my friend give me a 2jz-ge vvti , I know i can put the 1jz head on a 2jz no vvti bottom , but i dont know if the 2jz vvti bottom is the same as the no vvti
Old Jul 11, 2013 | 06:36 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
block is the same, aside from a potentially different size hole for the VVTI supply line... the pistons and rods are very different - the vvti pistons and rods are very weak in comparison to the non-vvti stuff...
Old Jul 12, 2013 | 10:05 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
mitsuguy is correct, 2jzge vvti rods are thinner and weaker, most don't exceed 3-400hp on these blocks for this reason. If you plan to do that you will be limited to lower boost levels. you really should find a non vvti ge block, or a 2jzgte block.
Halon
Sep 7, 2018 11:43 PM
fastjoon92
Oct 27, 2012 09:50 AM
Jacj3
Jul 20, 2012 01:39 PM
invasion
May 1, 2012 11:16 AM
