2JTsc300 NA-T BUILD
Old Oct 30, 2013 | 08:13 PM
  #61
2JTsc300's Avatar
2JTsc300
Old Nov 3, 2013 | 07:41 AM
  #62
2JTsc300's Avatar
2JTsc300
I was wrong on the boost. It made 403 wheel on 16psi
Old Nov 3, 2013 | 04:04 PM
  #63
SC4ME's Avatar
SC4ME
sweet, im so jelly
Old Nov 11, 2013 | 09:37 AM
  #64
97NaSupra's Avatar
97NaSupra
Great job man. I bet its a blast to drive. I hoping to mine tuned the beginning of next spring.
Old Nov 11, 2013 | 07:38 PM
  #65
2JTsc300's Avatar
2JTsc300
Thanks man. It is a blast to drive but sucks cause I get no traction lol. I ordered a trd lsd so hopefully that and shome wider tires will do the trick
Old Dec 7, 2013 | 03:50 PM
  #66
2JTsc300's Avatar
2JTsc300
spark plugs cover with word sanded off and painted pearl white
and also picked up a new TRD LSD so hopefully ill get some more traction with all this boost
Old Dec 12, 2013 | 06:18 AM
  #67
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
So where are we at with any updates? How has the car been running?
Old Dec 12, 2013 | 08:42 AM
  #68
2JTsc300's Avatar
2JTsc300
Car is running great and a lot of fun. Went to the track couple weeks ago and ran a 13.9 @ 111. Tires would not hook up until 3rd gear. In January I'm goin to install my TRD LSD and get some slicks and see if I can get into the 11's. Should be able too with this setup. Im also goin to install my new ls400 calipers on the front and ss brake lines. And once I get all that done we r goin to stat making my new front facing intake manifold and remove the wastegate and put a smaller spring and install boost solenoid and return it.
Old Dec 12, 2013 | 02:43 PM
  #69
SC4ME's Avatar
SC4ME
13.9? my car did 16 @100
Old Dec 12, 2013 | 08:33 PM
  #70
2JTsc300's Avatar
2JTsc300
That's not bad for not getting traction till 3rd gear lol. I should be in the 11's if I get traction
Old Dec 25, 2013 | 12:16 PM
  #71
2JTsc300's Avatar
2JTsc300
got some parts for xmas so now I can do my bbk upgrade and get my custom oil catch can made
Old Dec 26, 2013 | 08:00 AM
  #72
99SC42's Avatar
99SC42
what is your tire and wheels setup?
Old Dec 26, 2013 | 08:18 AM
  #73
2JTsc300's Avatar
2JTsc300
I took the NA supra wheels off our supra, they have 225 front and 255 rears, and they are falkens. im trying to get some 285 or 295s on the rear soon and put the 255 on the front
Old Dec 26, 2013 | 09:42 AM
  #74
99SC42's Avatar
99SC42
Falken is the worst pos tires you can put on your car.. i bought some wheels and they came with brand new falken azenis 615k 315/30r18 and they wouldn't hook for nothing even in 4th gear they spin.
I run a 3.26 ratio diff with no LSD with 18" wheels 315/30r18 Toyo and it hooks at 24 psi from 1st to 5th.
Now i am going with the 305/35/18 with TRD lsd and i am sure i won't have any issue.
You just need some better tires and you set!!
At 400whp you shouldn't have traction issue , but it also depend on your gear ratio of your diff.
Old Dec 26, 2013 | 10:44 AM
  #75
2JTsc300's Avatar
2JTsc300
I'm already looking for new tires. I have the stock 5sd gear ratio. I think it 4.08
