What 1JZ do I have???
Mar 17, 2013 | 09:45 AM
Can anyone tell which 1JZ motor I have? The old owner said from a Supra and another person said from a Soarer. It has an R154 and a Auto ECU.
I also ordered IS300 Fans to mount on the MK4 radiator. Do ya'll think they're going to fit with the IC piping?
Mar 17, 2013 | 10:09 AM
Likely Soarer from the few clues I can see here alone. Grab a picture of the ECU harness.
Mar 17, 2013 | 10:14 AM
Quote:
Originally Posted by
INTIMAZY
Kind of funny. I haven't even seen the car. I've been stationed in Nebraska and had my brother buy off one of my buddies back home.
Mar 17, 2013 | 10:37 AM
it's likely from a soarer as stated above, or a chaser with a switched oil pan. Best way to tell is to look at the ECU and the harness under the glovebox.
Mar 17, 2013 | 11:00 AM
To me it looks like a Supra, or Chaser judging by the TPS being located on the TB. My Soarer 1JZ doesn't have it there.
Mar 18, 2013 | 09:00 AM
You can also tell by the IAT sensor. JZA70s use the old round sensor plug, and the Soarer/Chasers use one like an Aristo
Mar 18, 2013 | 05:59 PM
Toyboxx
Your's is on the tb too. Your engines donor just didn't have trac control.
Engine is definitely not from a chaser/cresta/mark II. You can tell by the direction of the turbo outlet pipe.
lpolo69
Jan 30, 2006 11:36 AM
ippyness
Jun 8, 2005 11:21 AM
