Engine block coolant drain plug
Old Mar 14, 2013 | 04:10 PM
jsimms2's Avatar
jsimms2
Default Engine block coolant drain plug
I removed a brass plug from the rear passenger side of the engine block but no coolant came flowing out. Is there a brass plug back there not for coolant? Does coolant sit that low inthe engine that none would flow without the engine running? This is on a 95 sc300
Old Mar 14, 2013 | 04:26 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Moved to proper forum
Old Mar 14, 2013 | 04:44 PM
jsimms2's Avatar
jsimms2
Thank you, I am using the web browser on my phone and didn't make it to the right place.
Old Mar 19, 2013 | 07:54 PM
jsimms2's Avatar
jsimms2
Update:
This is the block drain plug. I had to stick a screwdriver in the hole and scrape out a bunch of crap and the redpowder water came flowing out. For what its worth this block drain plug was easy to remove, only had to remove intake piping and the exhuast heat shield.
Old Mar 20, 2013 | 01:10 PM
LEX_MAN's Avatar
LEX_MAN
I wondered for a while where it was. Thanks man!
Old Mar 21, 2013 | 07:30 PM
jsimms2's Avatar
jsimms2
Here is another picture of the location if anybody is having trouble. This picture is with the bolt already out. In the pic the drain hole appears directly above the O2 sensor.
Sunseek
May 12, 2019 06:25 PM
hatteroo
Maintenance
Feb 14, 2014 01:06 AM
schmoozer
13
Nov 9, 2012 11:56 AM
ltbong
Mar 3, 2010 04:33 PM
wbmx1981
Maintenance
Jan 26, 2010 10:50 AM
