rear subframe torque specs
Old Feb 25, 2013 | 05:55 PM
estomax's Avatar
estomax
Default rear subframe torque specs
Hey everyone,
i am looking through the FSM and cannot find any info on the rear subframe, specifically the 19mm front bolts and the 4x 12mm rear bolts that bolt onto the body of the car. What are the torque specs for those? Has anyone found it in the FSM ? I just spent 20 minutes searching it.
cheers,
Marko
Old Feb 25, 2013 | 08:42 PM
turbodremz's Avatar
turbodremz
IIRC the MK4 FSM states 136ft/lbs for the 19mm bolts going to the frame/unibody. As for the other, I cant say for sure but I think its 133ft/lbs.
Can anyone confirm?
Old Feb 25, 2013 | 08:52 PM
estomax's Avatar
estomax
hm. maybe i need to find a mk4 fsm then, cause i can't find the subframe in the sc300/400 one. do u have an mk4 fsm by chance? pm me a link to it or add me on skype or somethin
Old Feb 25, 2013 | 11:24 PM
turbodremz's Avatar
turbodremz
Check Supraforums.com, the one I had was from there. Im just going off memory cause the computer I had it saved on is long gone. There is a certain one that had all the specs, but a quick search there and you should find it no problem.
Old Feb 26, 2013 | 03:48 AM
iridebmx's Avatar
iridebmx
i am really good at searching so i'll help.
i found 133 ft-lb for the ***MK3*** supra
http://www.cygnusx1.net/Supra/Librar...aspx?S=MA&P=12
and
found 129 ft-lb for the ****MK4**** supra.......... go to 'MAINTENANCE'...... on PAGE 7 (ma-8)
http://www.97supraturbo.com/1997%20S...aintenance.pdf
Old Feb 26, 2013 | 07:44 PM
estomax's Avatar
estomax
there you go, the second link has it. I found this section in the SC400 manual now, the SC400 rear subframe calls out 28 ft lbs for the rear bolts (8) and the front ones call for 130 ft lbs (2)
this is on page MA-17.. very random.
the only thing i don't have now is the rear subframe mount, the big bolt that bolts the rear subframe mount to the subframe itself (big bolt.. probably 150-200 ft lb range)
Thanks!
Old Jun 20, 2018 | 11:30 AM
1997Soarer's Avatar
1997Soarer
The specs are hidden in the Maintenance section at the beginning of the Lexus aervice manual for SC300 & SC400s.
MY 1997 manual calls for rear subframe specs:
Subframe bolts to chassis (2 bolts) : 176 Nm 130ft-lbs
Subframe bracket to chassis (8 bolts) : 58 Nm 42 ft-lbs
Subframe bracket to subframe (2 nuts) : 76 ft-lbs
Anzelmi
Suspension and Brakes
Aug 14, 2017 10:43 AM
evbrad2002
RX - 1st Gen (1999-2003)
Jun 27, 2016 06:45 PM
theroots
Nov 18, 2014 07:14 AM
iambrink
Hybrid Technology
18
Oct 1, 2012 08:55 PM
Xylophone
Aug 8, 2012 02:39 PM
