Lets talk intake manifold...
Old Feb 17, 2013 | 09:56 PM
2jznosht's Avatar
2jznosht
Default Lets talk intake manifold...
My gasket has a leak and since I will need to pull the manifold. To me this sounds like a good time for an easy boost in power. Does anyone sell a better flowing intake manifold? If not would a port and polish be possibly/add power and be an asset to fi in the future?
Old Feb 18, 2013 | 06:40 AM
Djfoho's Avatar
Djfoho
there might be some for the supra counterpart that would fit if you can bother looking for them i assume your sc is n/a? and polishing isnt a bad idea might even give add a bit of power but still costly. you are better off going with a custom manifold if you can find one or just staying stock.
Old Feb 19, 2013 | 12:09 AM
2jznosht's Avatar
2jznosht
There isn't much out there about intake manifolds other than a couple front facing style ones. Apparently by doing that you lose power, or there are no gains....looks like the best option would be port and polish. Anyone have the specs, or some examples of a p n p stock intake?
Old Feb 19, 2013 | 08:48 AM
sj408's Avatar
sj408
One of the main reasons you lose power is having to remove the butterfly in the manifold which creates low end torque, I believe its called the acis system. You could take the time and port and polish your manifold, if you do please take many pics and share with us.
Though the gains wont be huge those are some of the little intricate things that contributes to a solid running car.
I would go with a simple gasket match port and polish as far as you can
Old Feb 19, 2013 | 11:16 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
There is no better intake manifold than the n/a setup for n/a applications. The whole design with the even long runners and the ACIS valve is what makes the 2jzge so zippy. you could do a basic port on the runners but it would be minimal at best. Just take it apart clean everything down new gaskets and enjoy.
also take the opportunity to change your plugs while you have the intake off.
Old Feb 19, 2013 | 11:51 PM
acl99's Avatar
acl99
Yeah unless having the FFIM is necessary for turbo fitment I would stick with the stock NA style intake manifold
LexusISF19
IS F (2008-2014)
May 29, 2014 07:57 PM
Specaiist
SC400 / 300 Classifieds
Apr 10, 2012 06:53 AM
Kevin@MVP
Performance
33
Mar 18, 2007 08:26 AM
MyScRuNmIa
Jul 18, 2005 10:39 AM
Ebanks
Mar 29, 2002 11:44 AM
