Turn light question...
On a Soarer...
When you turn on the indicator (either left or right), the fender indicator should flash, while the turning light (near the bottom of both bumper corners) stays illuminated while turning
well, my question was for the US market lexus... see i have ONE lexus light and everything plugs right up, except the turn bulb, which is a 3 pronged connector. The soarer one has only 2! Unless i can get a base from a soarer, i will have to do some surgery to the car
The other thing...
The wiper sprayer motor broke 1 nipple i think. I was wondering where can i get another one cuz the soarer i have has the rear wiper, so i don't think the US one will fit.
The other thing...
The amber bulbs, which you are referring to, are the turn signal indicators. It does not come on when you turn on the Headlamps. The base of the bulbs themself have two prongs.
Soarer_25GTT was a little confused on what your talking about, as well as I was. It was misleading and unclear, exactly what you were getting at, since your sig states that you will soon have a Soarer and that you already have a RX7.
ok ok... The Soarer I have has 2 prongs on the japanese turn light. The passenger side was replaced with a US headlight unit cuz it was scratched, but the base of the turn light has 3 prongs. I'm assuming that the year model of the new headlight assembly then is of a newer one because the connector on the Soarer has only 2 prongs.
I basically wanted to know if ALL the US cars had 3 prongs or that i just got a wrong model year so all i have to do is to find the correct base for the light.
The reason is because i went to a lexus dealer and they had a 3 prong turn signal base because the bulb is a 12W/8W bulb so it's a dual filament (according to the guy behind the desk)
Gaius
Dec 25, 2018 10:05 PM
Blueshark
Feb 27, 2018 06:04 AM
