Scwift92's Build
Old Feb 13, 2013 | 06:23 PM
kez's Avatar
kez
Originally Posted by ScWift92
i just got all my partsand my xs power ffim i have yet to rebuilt the turbo but will prob this upcoming Tuesday i plan to have the sc out soon shes running rich and also choking up
hows the swap goin?
Not motivated at all lol TO DAMN COLD!
Waiting on my FCD
And wheels are coming soon
Old Feb 13, 2013 | 06:29 PM
ScWift92's Avatar
ScWift92
Waiting on my FCD
do i need to go down there and motivate you?
nicee cant wait to see her in action i need to solve my fuel and idle problems than im good and after that ill be lending a hand also is your boy gonna buy those parts?
Old Feb 14, 2013 | 01:00 AM
kez's Avatar
kez
He said he was idk u should hit Em up to follow through
Old Feb 14, 2013 | 07:24 AM
ScWift92's Avatar
ScWift92
i did bro btw ima need your paint code :-x
Does any one know why my car hickups under throttle could it be ecu and i smell alot of fuel?
Old Feb 17, 2013 | 07:42 PM
2GSC300's Avatar
2GSC300
its more than likely the ECU
Old Feb 18, 2013 | 05:13 AM
ScWift92's Avatar
ScWift92
also i changed my efi relay and car started up but now the pump doesn't go on again when its realy cold the pump doesnt go on
Old Mar 1, 2013 | 10:26 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
It might just be me but it doesn't sound like its idling right, or running on all 6.
first inspect the cap and rotor easiest to check. either of those could cause you to be loosing spark on some cylinders and hence the rich smell.
If those are in good shape you could have an injector issue, or even an ecu issue. both of those things have happened to people before and have very similar symptoms cause the ecu can cause issues with the injectors.
Since it looks like you have 2 sc's I would first try swapping the ecu's to see if you have an ecu that went bad.
if not check the injectors out, maybe try the set from your other motor. you could start disconnecting injector clips one at a time and see if it smooths out to find the one thats bad. there may be a resistance check as well.
Since you said all your plugs look wet, and not just a few of them, I would try swapping the ecu before the injectors.
Old Mar 1, 2013 | 11:20 AM
kez's Avatar
kez
Aye Phil I had this issue a while ago it turned out it was my ecu. Try to swap it out with your old one
-Kyle
Old Mar 2, 2013 | 08:59 PM
ScWift92's Avatar
ScWift92
changed the ecu and still no start car cranks and everything else it threw a code 78
Old Oct 30, 2013 | 11:07 AM
ScWift92's Avatar
ScWift92
Its been some time since ive posted progress of my sc ive been dailying it so progression has been slow i am currently waiting for my control arm bushings to come in the mail
*I NEED YOUR HELP *
Should I Go?
NA-T or GTE
Goals Are 600hp on pump daily driven.
Old Nov 13, 2013 | 01:20 PM
ScWift92's Avatar
ScWift92
Instead of creating a new thread i have a question i have two ecu's
#1) The original ecu that came with the car works fine the car idles well and drives very responsive "BUT" transmission bounces from 3rd gear and 4th gear and well never really goes into 4th gear .
#2) This Ecu is from my first sc and the car goes into all gears "BUT" doesn't always feel so responsive in throttle and when at a light the car idles super low even after adjusting the throttle cable
What Can It Be?
Anybody have a clue i need answers.
Old Dec 5, 2013 | 08:58 AM
Answer300's Avatar
Answer300
did you have idle issues before? this is going to sound weird but do a scan on your charging system. if you don't have 100% continuity, it will give you some headaches as to tracing the exact problem. are you using the same transmission that came in the car along with its original electronics?
Old Dec 12, 2013 | 07:56 AM
ScWift92's Avatar
ScWift92
Im Using the stock A340 For now and i still have idle issues im going to buy another ecu after the holidays.
Old Jul 13, 2014 | 08:41 AM
ScWift92's Avatar
ScWift92
This is how the car currently looks I'm looking to sell it to get an original 5 speed or maybe 2gs I will miss it
Attached Thumbnails Scwift92's Build-img_20140612_151232.jpg   Scwift92's Build-img_20140709_173911.jpg   Scwift92's Build-img_20140707_135718.jpg
madchyers
IS - 1st Gen (2001-2005)
39
Aug 19, 2019 04:52 AM
Weapon F
Apr 5, 2012 06:28 AM
Weapon F
Jan 23, 2012 10:32 AM
Weapon F
Apr 25, 2011 08:00 PM
